XL500R plastic air filter case. It's like a rubix cube!!!!
baldock
Beitrag von baldock »
how does the plastic air filter case fit back into the frame?
There must be a trick to this. I seem to remember the only way I could get it out was with the rear wheel removed.
I've tried pushing it in from the rear but its just too wide to go through.
Re: XL500R plastic air filter case. It's like a rubix cube!!!!
Take a look at this Thread:
viewtopic.php?f=62&t=5925
The rear wheel and the shock absorber must be removed.
Greetings Gunnar
baldock
Many thanks.
Strangely, I did a search and nothing came up.
It went in easily by just removing the shock absorber. I left the carburetor and shock linkage still in place.
