Camshft too long?
baldock
Camshft too long?
Beitrag von baldock »
The cam doesn't sit in the recess that was machined for it.
It seems to be too long.
UPDATE: I've just measured the length against the old one and they're the same. Also shone light down and appears to be a chamfer NOT a step.
Just found a picture I took on disassembly and it was the same before :)
Re: Camshft too long?
:top:
The screws for the timing chain sprocket do not look original. The main thing is to put 17 Nm on it.
I thing that these screws have special dimensions do fix the sprocket in position and are special hardened.
I have the original screws in good used condition for you
baldock
Thanks everyone, but hopefully that bolt will be OK. One got rounded off and this is a genuine Honda bolt with the same part number (although it does look slightly different with the flange).
